Part Number: TCAN1043-Q1
Other Parts Discussed in Thread: TCAN1043
Hi team,
I would like to confirm about how TCAN1043 behave under CAN-bus Wake use case.
As far as I see the datasheet, when TCAN1043 is in Sleep mode or Standby mode, the device could shift to standby mode and toggle INH =H only by Wake Up Pattern (and Wake Pin).
Q.1) This means, when ECU starts CAN communication between the ECU in Sleep/Standby mode, if Wake Up Pattern is not sent previously, the communication will fail.
Is it correct?
Q.2) Above scenario is compliant to ISO 11898-2?
