Other Parts Discussed in Thread: TPS65981, LM25066, TPS2480
Hi TI expert,
May I ask if TPS65981 can protect the MOSFET when short circuit happen in the output side?
Dora
Hi Dora,
Yes, the TPS65981 has over current protection and short protection on all of the power paths. The over current protection is configurable through the TPS6598x Application Customization Tool.
If this answers your question, PLEASE select This resolved my issue
Thank you,
Eric
Hi Dora,
The TPS65981 only does short and current protection when it is acting as a Source. Per the PD Spec, only the Power Source needs to provide protection. There is not protection on the FETs with TPS65981 when it is acting as a Sink as it is expected that the Source device will have the required protection.
Thank you,
Eric
Hi Dora,
Section 9.3.3.4 through 9.3.3.15 highlight the different over-current and Hard Short protections on all of the TPS65981 power paths. There are also plots showing the response time in those sections.
Thank you,
Eric
