Part Number: UCC20520
Hi there,
I seem to have an issue when using this gate driver to drive two n-channel MOSFET's in a motor controller circuit. It seems that the output B is in phase with the 31kHz PWM while output A is complementary to the PWM input form the datasheet this should be the other way around i have tried this on three gate drivers and am getting the same result each time. Is there reasoning behind this.
