TUSB1046A-DCI: Registers that should be changed from default value
Guru 29720 points
Part Number: TUSB1046A-DCI
Hi Team,
My customer considers to evaluate TUSB1046A-DCI in his application board.
They wants to set EQ setting from registers so I understand they should set EQ_OVERRIDE then adjust the following EQ setting at the beginning.
- DP0EQ_SEL, DP1EQ_SEL, DP2EQ_SEL, DP3EQ_SEL, EQ1_SEL, EQ2_SEL, and SSEQ_SEL
Is there other registers that should be changed from default value?
Yaita / Japan disty
