Part Number: DS100BR410
Can this device be used as a repeater for M-PHY signals as specified in in https://mipi.org/specifications/m-phy
- DC-coupling: the datasheet does not explicitly say AC-coupling, the test circuitry shown and the condition-text in the electrical characteristics does mention it. DC-coupling is needed, as M-PHY defines bus-states, where a static logic level needs to be driven. Plus, the bus data rate can vary between ~600MT to ~8GT.
- interfacing to VML logic possible.
- logic levels up to 620mV differential (non-terminated), common mode at half that voltage.
Further, does this device require external pull-up resistors at the drivers?
Thank you for any information in advance.
