Part Number: DP83822I
Hi
Our customer measured EMI noise on their board. They found some noise(high peak noise) around 60MHz~110MHz and it was from DP83822I.
Is there any way to reduce that noises? I found the function that as Scrambler function.
What register we should set to enable this scrambler function? (Is that PHYSCR[11]?)
Could you give any advice if there is any other way to reduce the noise?
Koji Hamamoto
