Part Number: TPS2553
I'm testing the TPS2553 in our application and we have set the current limit threshold for 1.5A. I can hook up a constant current load and increase this past the threshold. The TPS2553 seems to detect the current limit correctly and limits the output but does NOT assert the FAULT# output.
I thought the datasheet describes this behaviour so what could be wrong? I previously raised an issue regarding the failure of the device to assert FAULT for its advertised reverse voltage protection feature. Is this another example of something that doesn't work on this part?
Shareef.
