Part Number: TPS2141
Other Parts Discussed in Thread: TPS2001D, TPS2065D, TPS2553, TPS2552, TPS2069D, TPS2069
Hi team,
Question about the TPS2141 LDO functionality. Since the LDO has a separate enable line, can I disable the LDO and use the switch separately? Should the LDO pins be tied to GND?
Also, do you have any other recommendations for load switches similar to the TPS2141 without the LDO? I was looking at the TPS2001D and TPS2065D, are these good recommendations?
Thanks for the help,
Arthur
