Part Number: DS90UB940-Q1
Other Parts Discussed in Thread: ALP
Tool/software: Linux
hi
I use the platform is imx6+947+940
947 input is Single-pixel mode.output is port0
940 output 2 data lanes, 1 CSI port active
1: entering bisten mode, 940 lock pass is high but mipi clk output is only 33Khz
Switch to normal mode 940 lock pass is also high mipi clk only 33khz
Turn off 947 and enable 940 PATGEN_EN 0x64=0x11 mipi clk output 33K
2: The default value of 0x02 is 0 after each power-up 940
Please help me. It has been several months.
Thank you.
bisten mode 947 reg:
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 34 00 00 d2 80 00 58 00 00 00 05 00 07 20 00 00 4..??.X...?.? ..
10: 00 00 00 88 00 00 fe 1e 7f 7f 01 00 00 00 01 00 ...?..?????...?.
20: 0b 00 25 00 00 00 00 00 01 20 20 a0 00 00 a5 5a ?.%.....? ?..?Z
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
40: 14 55 00 00 80 00 63 00 00 00 00 00 00 00 00 40 ?U..?.c........@
50: 16 00 00 00 02 00 00 02 00 00 dd 20 02 06 44 35 ?...?..?..? ??D5
60: 22 02 00 00 10 00 00 00 00 00 00 00 00 00 00 00 "?..?...........
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
c0: 00 00 80 00 38 00 00 60 c0 00 00 00 00 00 ff 00 ..?.8..`?.......
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 80 00 28 38 00 00 00 00 00 00 00 00 00 00 ..?.(8..........
f0: 5f 55 42 39 34 37 00 00 00 00 00 00 00 00 00 00 _UB947..........
biste mode 940 reg:
00: 58 04 00 f0 fe 1e 00 00 00 00 00 00 00 00 00 00 X?.???..........
10: 00 00 00 00 00 00 00 00 00 01 00 00 22 40 00 00 .........?.."@..
20: 00 00 00 20 08 00 83 84 20 00 00 00 00 00 00 00 ... ?.?? .......
30: 00 00 90 25 01 00 00 8a 00 00 00 05 20 e0 23 00 ..?%?..?...? ?#.
40: 43 03 03 00 60 88 00 00 0f 00 00 08 00 00 63 00 C??.`?..?..?..c.
50: 03 10 00 01 80 00 00 00 00 7f 20 20 00 00 00 00 ??.??....? ....
60: 00 00 00 00 10 00 00 00 00 00 00 00 00 01 00 00 ....?........?..
70: 00 00 00 07 07 08 00 00 00 00 00 00 02 00 00 00 ...???......?...
a0: 00 00 84 00 00 00 00 00 00 00 00 00 00 00 00 00 ..?.............
c0: 00 00 00 00 00 00 00 00 c0 00 00 00 00 00 00 00 ........?.......
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 5f 55 42 39 34 30 00 00 00 00 00 00 00 00 00 00 _UB940..........
normal mode 947 reg:
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 34 00 00 d2 80 00 58 00 00 00 22 00 17 20 00 00 4..??.X...".? ..
c0: 00 00 80 00 38 38 00 60 c0 00 00 00 00 00 ff 00 ..?.88.`?.......
normal 940 reg:
00: 58 04 00 f0 fe 1e 00 34 00 00 00 00 00 00 00 00 X?.???.4........
10: 00 00 00 00 00 00 00 00 00 01 00 00 23 40 00 00 .........?..#@..
20: 00 00 40 20 08 00 83 84 01 00 00 00 00 00 00 00 ..@ ?.???.......
30: 00 00 90 25 01 00 00 8a 00 00 00 00 20 e0 23 00 ..?%?..?.... ?#.
60: 00 00 00 00 10 00 00 00 00 00 00 00 00 03 00 00 ....?........?..
