Part Number: TUSB7340
Hi Sir,
We have a yellow bang out issue on the TUSB7340 controller with Intel Coffee Lake.
There is a PCIe to USB card which design with TUSB7340, but we only used to connect to USB2.0 connector.
P.S. This PCIe to USB card has used several platform before Coffee Lake, and no issue.
FAIL symptom:
Let system go into S4 or S5, check the monitor is off. Install the USB device then press Power button to start system, it will spend long time in OS loading and found USB KB/or MS not responding, and a yellow bang about "Texas Instruments USB 3.0 eXtensible Host Controller-0.96(Microsoft)" showing up in Device Manager. To recover that, you should unplugging the USB KB/or MS and then restarting the system and plugging it back after system wake up.
May I know do you ever face this issue before?
Please kindly give us some advice.
Thank you.
Edward Chen
