Part Number: TPS65982
Other Parts Discussed in Thread: TPS65983B, TPS65981, TPS65981EVM
Hi Sirs,
Sorry to bother you.
We have design TPS65983B, But we know 983B only for Intel reference schematic, so we will use TPS65982 in next schematic version.
Our application is use TypeC DP signal to turn on monitor
We have made mistake on schematic. We connect TPS65983B SPI pin to GND.
We couldn't burn in anything that will effect the 983B couldn't working on M/B.
Because it's urgent case and layout issue, we couldn't cut open these pin.
We have TPS65982 EVM on hand, so have any idea to make our board to work?
Such like use I2C Interface to add command by BIOS side on debug mode? or use TPS65982 EVM to jump from our board?
Any question and suggestion are welcome.
By the way, except SPI error, could you help double confirm our schematic again?
Soft remind, for now our board is TPS65983B, We just need use Type C DP to turn on monitor on this version. We will have follow your suggestion and use TPS65982 on next schematic version.
Schematic:
TPS65982.pdf
Many thanks!!
