Part Number: DP83630
Other Parts Discussed in Thread: DP83620,
HI Team,
I am planning to use DP83620 Ethernet PHY IC for my embedded application as a replacement of AM79C874 IC.
To test the functionality of DP83620 TI is providing a EVK kit.
There is another kit for DP83630 which appears to be identical (with more functionality) in terms of features and EVK boards design, I have also compared the available schematic and the only difference I found was certain pins in 620 are reserved while in 630 are used as GPIOs.
My query here is whether I can order the EVK kit for DP83630 for testing the functionality and later use DP83620 IC in my design??
Thanks you.
