TRS3122E: Figure 9.2 from the spec sheet should NOT work...requesting clarification
Part Number: TRS3122E
While designing a customer solution around the TRS3122E, I noticed that in Section 9.2 (Typical 1.8-V Application), Figure 13, on page 16 of the spec sheet for the chip, that the outputs on the left side in the figure (labeled "PCB1") are connected to the outputs on the right side of the figure (labeled "PCB2"). Similarly, the inputs are connected to the inputs of the labeled design blocks.
Is this correct? It doesn't seem so; should not an input be connected to an output, and vice-versa?
I've ordered a couple of the development boards, but as they're days away, I was wondering if someone knows what's up with this.
Thank you for your time and consideration!
