DP83848I: DP83848I
Part Number: DP83848I
In the process of using the DP83848, I encountered some problems:
1. The PHY chip DP83848 was used on our equipment to process network data, and an "ETHERNET FRAME CHECK SEQUENCE INCORRECT" error occurred while processing the ARP address packet.
    The data that my device grabbed after processing the ARP packet is correct. After DP83848 chip processing is sent to the switch,
The wireshark software captured the ARP address packet and found that the "Franse check sequence" was incorrect and the frame check fcs error.
Therefore, we doubted whether it was the DP83848 frame check issue.
Eric
