SN65HVD1471: Hardware interface with microcontroller
Part Number: SN65HVD1471
Dear sir,
i bought SN65HVD1471, for communicating PIC18F65K40 using RS422 protocol. I can't able to understand, how it's interfacing with DB9 connector and also where to drive output and to give input in this transceiver IC.
Sabitha
  • Hi Sabitha,
    The SN65HVD1471 transceiver takes a D input from an MCU to drive a differential signal onto the Y/Z bus. The R pin is an output to an MCU from the differential signal on the A/B bus. The RE and DE pins are inputs from the MCU to enable and disable the driver and receiver.
    Could you send a diagram of your application including the DB9 connector with pins labeled? I'd like to understand your question with more clarity.
    Max Megee
