TPS65986: v. TPS65981 differences
Part Number: TPS65986
Other Parts Discussed in Thread: TPS65981, TPS65982
1.What is the difference between TPS65981 and TPS65986?
2. Does it support DisplayPort (DP) alternate mode negotiations?
3. Interface type used to control external MUX?
4. Is Bill board device class supported?
5. Apart from TPS6598x series are there any other integrated solutions targeting DisplayPort Alternate Mode?
6. Apart from power control interface is their any difference functionality wise?
  • Hi Kevin,
    1. The main difference between the two devices is that the TPS65981 has the capability of using an external power path in addition to the two internal power paths. The TPS65986  only has the two internal power paths
    2. Yes they do. All Type-C PD controllers need to have the ability to support DP alternate modes.
    3. Both the TPS65981 and the TPS65986 use GPIOs to control an external high speed MUX
    4. Yes
    5. No, our USB Type-C PD controllers (TPS65981, TPS65982, TPS65986) are the only integrated solutions for alternate modes as they are required to support them per the USB Type-C PD spec
    6. Not really. Both can accomplish the same thing. The TPS65981 has the external power path while the TPS65986 has a few more available GPIOs to use and configure.
    Let me know if this answer your question! If so, please click This resolved my issue.
