Part Number: TUSB1064
I'm designing system having DP sink through Type C connector and found TUSB1064/564 could be placed to sink side as active crosspoint switch, redriver and solution for cable flip. System will be fixed as 4 lane DisplayPort alternate mode supporting UFP config case "C" only. It's use case "9.3.3 DisplayPort Only" from the data sheet.
However, it's a bit unclear can this component work straightly from the native DP source also? With DP to Type C adaptation of course.
I would like to continue discussion via email if possible so system details could be shared more in detail.
BR,
-juha-
