DS90LV804: LVDS Drive Current VS Load
Part Number: DS90LV804
We are planning to use the DS90LV804 LVDS buffer/repeater in our system to drive LVDS signals at 250 Mbps (ADC output data lines) through a 3 metre length of Cat6 cable. I’m assuming that since LVDS uses a current-mode driver there is no current dependence on the capacitance of the cable or on capacitance of TVS diodes used at the cable-side of the buffer/repeater? And that we can therefore expect power supply current for 250 Mbps data rate to be as shown in Figure 6 of the datasheet, i.e. < 140 mA?
Peter.
  • Hi Peter,
    The current requirement will typically be < 140mA with a clock or PRBS pattern at 250 Mbps.  The current demand will not change based on cable length or TVS diode capacitance.  I would recommend to use low capacitance TVS diodes to ensure minimal distruption of the signal quality.
    Lee
