TPS65981: Test of TPS65981EVM alone (no DP-EXPANSION-EVM) connected to a USB-C PD power supply
Part Number: TPS65981
Other Parts Discussed in Thread: , DP-EXPANSION-EVM
Would you kindly comment what is the minimum evaluation board setup required to test an external USB-C PD power supply?
We intend to have our design fed through TPS65981 connected to an external power supply (an off-the shelf item not monitorable), and USB data communication is not needed.
To speed the design, we'd like to test the topology using eval boards, but we are not sure if only 1 unit of TPS65981EVM is enough for monitoring the power delivery, and also not sure if DP-EXPANSION-EVM is needed.
Best wishes,
