Part Number: DS110DF410
the board with DS110DF410 supporting 10Gbps application. customer report high bit error rate while unplug the SFP+ cable and plug the SFP+ cable again.
issue descriptions (step by step):
1) plug the SFP+ and power up the system, 10Gbps communication function well(no bit error)
2) remove the SFP+ cable then plug the SFP+ cable back again(bit error happen)===> issue
3) if in step 2) then reboot the system again, there is no bit error problem.
I capture the register map in with and without bit error condition. I found it might due to CDR unlock.
questions:
1) Does the DS110DF410 need load its configuration again while SFP+ cable been remove and plug it back?
2) Can you review the register map and support your thoughts?
