Part Number: DS90C187
Hi team,
We have found the following result on our android/Linux system.
The Host CPU has two LCDC, we use LCDC1 as source of LVDS DS90c187.
Use fbset get the following message.
mode "1600x900"
geometry 1600 900 1600 900 16
timings 0 200 40 30 2 40 2
nonstd 4
rgba 5/11,6/5,5/0,0/0
endmode
The Panel spec refer to “2018-06-06 17_195WD1_Panel_Spec.png” as attached and the Panel support 16.7M color(RGB888).
Is the circuit support 24bit color display supported?
If not, can you help us on this application with your recommendation.
please refer to the schematic and panel spec.
Many thanks for your helps!
