Part Number: TPS65987D
Hi, Team,
My customer plan to use TPS65987D with TUSB1046. The customer may use the below GPIO.
CTL1 Port 0 DP Mode Selection Event (DP_Mode_Selection_Event_Port1)
CTL0 Port 0 USB3 Event (USB3_Event_Port1)
FLIP Port 0 Cable Orientation Event (Cable_Orientation_Event_Port1)
Is it possible to use GPIO described as "Push pull" in Open Drain? On the Host Interface Guide, only USB3_Event_Port1 had Open Drain and the other two were Push pull. There are check Open Drain output box on the customization tool are they consider to use it as Open Drain output.
Satoshi Yone
