Part Number: DS9638
Other Parts Discussed in Thread: THVD1551
Hello to All....
Does anyone know what the actual output impedance of the DS 9638 RS-422 line driver chip is in ohms?
Thanks!
Dan
Part Number: DS9638
Hello to All....
Thanks!
Dan
Max:
Thanks for the response!
I was thinking of using the DS9638 as an output buffer for a SPDIF digital audio
signal. I am sure that you are aware that a 75 ohm value is required for an SPDIF
output impedance, and that 75 ohm BNC jacks are used with a 75 ohm coax cable.
It sounds like the DS9638 has an output impedance that varies in a way that would
make it very difficult to get a steady 75 ohms output impedance with a series output
resistor. Would you agree?
Thanks again!
Dan
