Part Number: TPD3S714-Q1
can this Part be used to reliably used to switch the Datalines via the !EN Pin?
Or is there a problem regarding USB-OTG Support, where the Datalines remain active after disabling the IC?
Thanks for the Help,
Tim
Tim
Hello Chuck,
i observed the behaviour you described where the Signal passes through the disabled chip.
Is there any way or IC-Solution where i can reliably switch of datalines without any coupling?
For axample a switch which either routes the signal through or onto an 45 Ohm resistor to reduce any reflections.
Tim
