Other Parts Discussed in Thread: DP83867E, DP83867IS, DP83867CS
In my board I have 2 number of SerDes Ports (1000-Base-Bx). I have decided to convert the 1000Base-BX to 1000Base-T. For that I I have planned to use the Ethernet PHY transceivers
In my Board Intel I210-IS (PCI-MAC Controller) is used to get the 1000 Base-BX.
In the I210 datasheet, they have mentioned that, the IC will support for the SerDes/SGMII ports.
In the TI part it is mentioned that, it will support SerDes? May I use the same transceiver for the SGMII interface?
Is there any difference between SerDes & SGMII? Can any one clarify?
