Part Number: SN65DSI84
Should the pcb trace is routed with controlled differential 200Ω impedance if using SN65DSI84 with the 200Ω differential termination ?
Kato
Kato
Hi I.K.-san,
Thank you for the information.
I believe that the pcb trace should be routed with controlled differential 200Ω impedance if setting "1" to "CHA_LVDS_TERM" and "CHB_LVDS_TERM" but would like you to confirm just in case.
In addition, would you recommend to use SN65DSI84 with 200ohm differential termination ?
Kato
