TPS65987D: Veder ID configuration of TPS65987DDH
Part Number: TPS65987D
Hi, Team,
We have question for TPS65987DDH vender ID. Could you support this?
·Should the customer describe their Vendor ID at each below register and all IDs are the same?
0x47 Transmit Identity Data Object
0x73 Tx Manufacturer Info SOP
0x7f Tx Manufacturer Info SOP Prime
0x77 Tx Source Capabilities Extended Data Block
· Is this ID a hexadecimal number?
· Is Manufacturer String optional?
· Manufacturer XID is a number to apply by acquiring to USB IF?
· Is Firmware Version, Hardware Version optional?
Satoshi Yone
  • Hi Yone-san,
    Yes, the customer should enter their vendor ID in all of the registers you had listed when going for USB PD certification.
    The Vendor ID is a Hex number. The manufacturer string is optional.
    Yes, the manufacturer XID is received when they go for certification with the USB IF.
    Firmware Version and Hardware Version are also optional fields.
    If this answers your question, PLEASE select This resolved my issue
    Thank you,
    Eric
