Part Number: LMH0318
Other Parts Discussed in Thread: LMH0324, LMH0056, LMH0034, LMH0303
Is it possible to use LMH0318 to mux two single ended 75 Ohm HD-SDI inputs to one single ended 75 Ohm HD-SDI output? Could I just convert it from 75 Ohm to 50 Ohm on the input sides and terminate the inverted input or would I need a cable equalizer to convert it to 100Ohm before going into LMH0318? Thank you
