Part Number: PCA9518
Can I use PCA9518 and TCA9617 in series?
Hi Bobby,
I suspect yellow is B side of the TCA9617 and green is A side of the TCA9617 and the master/slave is pulling low on some other channel on PCA9518?
[Kanava]: No, Yellow is A side - SDA, Green is A side -SCL.
Attached screen shot of A and B side of SDA.
Do you have a schematic showing the PCA9518 and the TCA9617 (pull up resistors or any series resistors)?
[Kanava]: I will share the details later.
Can you remove the TCA9617 and populate a new one and check to see if this still occurs?
[Kanava]: I will try to probe the signals in other boards.
Are you having any issues with the signal integrity?
[Kanava]: Signal doesn't look clean. I am trying to understand why A side signals are also getting "inverted pedestal" when we are expecting it only on B side
Can I connect A side of TCA9617 to EXPSDAx/EXSCLx of PCA9518?
-Kanava
