Part Number: SN65HVD888
Hi Team,
One of our customer is using SN65HVD888 and having following queries, in the application where it is used for more than 200 nodes with any node can be master at a time,
- Can we have all nodes to be with 888 device?
- Where should the failsafe resistors to be connected?
- Because of external failsafe resistors, is there any limitation on maximum number of devices or data rate or throughput?
- Inputs/ reference for differential termination resistor scheme for 888 device with failsafe resistors.
Can you please help with your valuable inputs.
Regards, Shinu Mathew.
