Part Number: DS90UB954-Q1
Dear TI Experts,
I am now using ds90ub960/ds90ub964/ds90ub954,and have some layout problem needs your suggestion:
DS90UB954:
1:I have read the Layout Guide,and don’t find the description of layout line impedance between 954 and AC coupling capacitors, must it to be 100Ω impedance?
2:Must the bottom reference layer of AC coupling capacitors be hollowed ? DS90UB954 EVM does the hollowing,but I cann't find the description in the Layout Guide
By the way, It's found in the layout guide that the reference layer of the magnetic bead connected to RIN+ need to be hollowed out, but DS90UB954 EVM didn't do the hollowing
DS90UB964:
Their is not much layout guide in the 964 datasheet besides a picture, what's the best way to do this?
DS90UB960:
AC coupling capacitors hollowing;three magnetic beads hollowing。
And the two GND,GND2 is layer4,between these their is a signal layer
960/954/964 layout guide are different from EVN,I'd like to confirm which should I refer to?Cause I am now optimizing the layout.
You can refer to the layout picture in the document.Hoping for your reply,Thank you very much~Layout.zip
