TFP401: td(st) condition
Guru 19685 points
Part Number: TFP401
TFP401 Datasheet is described td(st): 0.25 tpix and Test condition is STAG = low, PIXS = high.
Is td(st): 0.25 tpix timing spec depend on Test condition?
For example, when STAG = High, PIXS = Low, is td(st) spec change?
If Yes, please let me know about td(st) timing spec for the other condition.
Satoshi
  • Hi Satoshi-san,
    That specification is for time-staggered pixel outputs during 2-pixel/clock mode, which is why it's defined under those test conditions. Namely, you would only care about that spec when STAG is low and PIXS is high. It would not be correct to test it under any other test conditions.
    I.K.
