Part Number: DS90UB925Q-Q1
Hi team,
The 926 925 topology is as follows, mainly want to implement cpu-i2c-926-925-i2c-slavex, to configure the slave. Then read the business data back;
At present, it is found that the slave cannot be queried through the CPU. It may be a configuration problem. The current 926 configuration is as follows:
The register is read back as follows (0x1C=02 is found, it is not clear why)
Could you please help confirm if there is a problem with the 926 configuration?
Thanks & Best Regards,
Sherry
