Part Number: LMH0387
Other Parts Discussed in Thread: LMH0397
Hi Team,
Could you please advise us how to control 75ohm impedance under LMH0387 device ?
Trace impedance from connector to device can be controlled by trace width and the depth to the GND or VCC reference plane.
Since LMH0387 integrates the return loss network, I wanted to know what would be the recommended depth (distance) to reference plane under the device.
Can we just place 75ohm reference plane underneath which designed based on the trace width ? (Reliefs on above layers.)
Another question I have is that closely looking to the LMH0387EVM PCB design, it seems left half uses 75ohm reference and right half uses 50ohm reference.
However, this is not described in the datasheet.
Do you need to place 50 ohm reference plane underneath the device ?
If you do, from where do we need to split the reference plane ?
Kawai
