Part Number: DS90UB954-Q1
Hi team,
Please tell me how to change from synchronous clock mode to asynchronous clock mode at 954.
I understand that it can be selected at startup by voltage setting of MODE terminal.
I'd like to know if it can be switched with a register like 953.
We want to use both synchronous mode and asynchronous mode using the same hardware.
And we do not consider switching dynamically while operating it.
Boards used asynchronously are always used asynchronously, but I do not want to change the resistance of the MODE terminal for each board.
Since 953 can be changed asynchronously in the register setting, I thought that 954 could be changed by register as well, but I could not find it in the datasheet.
954 can not set the mode with a register like 953?
Tomoaki Yoshida
