Part Number: DP83867CR
My customers have the following results at 1000 BASE - T Compliance Test.
- 1000 Base-T, Difference A,B Peak Output Voltage(w/ Disturbing Signal) : Failed
- 1000 Base-T, Point F Template Test(w/ Disturbing Signal) : Failed
- 1000 Base-T, Point H Template Test(w/ Disturbing Signal) : Failed
- 1000 Base-T, Transmitter Distortion(w/ Disturbing Signal) : Failed
- 1000 Base-T, MDI Common Mode Output Voltage : Failed
So I have a question.
1. Is there an adjustment register to pass the Compliance Test?
2. Is there a way to connect external components such as resistors to adjust Compliance Test and adjust it?
I appreciate your cooperation.
Kaede Kudo
