Part Number: TPS65982
Dear,
For TPS65982DC, my customer have following problem for the plug insert or removal:
The test setup is inserting the adaptor, power on the notebook system, and after the power on, remove the adaptor, read the 0x15 register, Byte1, bit3 "Plug Insert Or Removal", the status is 0, which shows no USB Plug Status changed, but when plug in the adaptor again and then plug out, the status changed.
The question is why in the first time when plug out the adaptor, the plug insert or removal status don't change.
BTW, in the FW, I have already checked the "Plug Insert or Removal".
Could you please help give some suggestions?
Thanks.
