Part Number: SN65DP159
Hello.
I have a question about SN65DP159RSB.
Q1
I want to stop TMDS on the output side with I2C.
Is there a corresponding register?
Q2
When I2C power down (0x09 3 bit) is done,
The register setting value is not cleared.
Is this understanding correct?
Q3
Data Sheet 10.3.1 Compliance Testing has a description of setting values to pass compliance test.
Is there something you do not pass the test if you use it by default (automatic setting)?
Also, are there other recommended settings?
Thank you.
