Hellow,
I have problem with my DP83867IS. I connected it to sgmii, who had not clock recovery and need clock from phy, i write extended register to support 6-wire sgmii, but i has changing signal only on data output lvds. When i set extended register as support 6-wire sgmii, the clock is started but works only approximatly 3 seconds. Is it normal? May be you have this problem?
