Part Number: TCA9539
Hi Sir:
Does TCA9539RTWR offer I2C bus time out feature when a serial interface
transmission is interrupted ?
Gorden
Hi Sir:
Gorden
Hey Gordon,
I have not heard of I2C standard defining a time out parameter. doing a ctl+f and searching time out in both SMbus and I2C standard, I was not able to locate anything about this.
None of our devices have a time out feature because it was never defined in I2C spec.
-Bobby
Edit: SMbus does define timeout (had to search timeout without a space) however our devices are defined using I2C standard.
Hey Gorden,
"I would like to know,Which of TI 2C general purpose I/O products which one of parts has support I2C time out except TCA9539."
None of our IO expanders have an I2C time out feature.
May I ask what end equipment/application you are trying to design? This is the first request we've had for an I2C timeout for our IO expanders. This seems like a gap in our portfolio and I would like to understand in which end equipment this feature is necessary. Likely I can pass this on to our systems engineer who may in the future, specify a time out feature in our future IO expanders.
-Bobby
Hey Gordon,
"If I2C Bus interface transmission is interrupted,Our MCU send STOP condition and then issue start condition which TCA9539
can re-connect I2C BUS communication ?"
No, the TCA9539 will get stuck if you are in the middle of a transaction. You will need to send 9 clock pulses onto the SCL line before performing another I2C start condition.
-Bobby
