Part Number: DP83867CR
Hi Team,
We design a board with DP83867CR, and need to check the ethernet compliance test.
TI provides the compliance test guide : SNLA239A "How to Configure DP838xx for Ethernet Compliance Testing". The appendix B of this guide contains register settings for outputting test mode signals.
At first, we set the MDIO registers for 1000 Base Test Mode 1 (same as the guide) :
Reg 0x001F = 0x8000 //reset PHY
Reg 0x0000 = 0x0140 //1000 Base-T Mode
Reg 0x0010 = 0x5008 //forced MDI Mode
Reg 0x0009 = 0x3B00 //Test Mode 1
Reg 0x0025 = 0x0480 //output test mode to all channels
Reg 0x01D5 = 0xF508
Pair-A test mode 1 signal output normally, but pair-B/C/D test mode 1 signals don't output. So we can't check the ethernet compliance test.
Q: Are the MDIO register settings of SNLA239A correct, even in DP83867CR?
If no, could you show me the setting?
Thanks in advance.
Hiroshi Sakurai
