Part Number: SN75LVCP600S
Other Parts Discussed in Thread: ALP,
Hi Sirs,
Sorry to bother you.
We'll fail the OOB on SATA SI test,
Is this a IC electrical characteristics? how to fix it?
Thanks!!
Hi Sirs,
Thanks!!
Hi Sirs,
Actually the SQ_TH is set “0” (not “1”) in our design.
So, have any suggestion can share?
We saw there have discussed similar topic before, so does 600s have passed the OOB test?
This device has passed OOB SATA testing. Here is a file of the test report.
TI-SATA-Repeater-RSG-Gen3_Results.xls
Lee
Hi Sirs,
Thanks for your reply,
1. Where have show OOB passed on this excel file?
2. How to fix our OOB test fail even our SQ_TH is set “0”
Hi Sirs,
Thanks for your reply.
I've send a friendship request to you.
I could send you our schematic and test result off line.
Thanks!!
Just wanted to post this on E2E as well. The SN75LVCP600S has an ALP (Automatic Low Power) mode. The first test in this OOB sequence is showing the impact of this feature. When operating in a regular system environment this feature does not impact normal operation. The first OOB pulse is shortened due to the wakeup time of the SN75LVCP600S, following OOB pulses are of the correct duration.
Lee
