Part Number: DS110DF410
Does the DS110DF410 support SAS-2? If not does TI have a retimer (with CDR, not a repeater/redriver/equalizer) that does?
Thanks for the quick response. My suspicion was that the OOB was the issue.
Our application is an embedded defense application between two units that are connected by a cable. Each unit has a number of connectors and PCBs in the SAS path so we'd like something that can perform retiming to address the impedance mismatches/discontinuities and corresponding reflections internal to each unit. Equalization addresses the cable issues, but not the impedance issues.
Transmission like mis-match/reflections could be problematic for retimers. DFE could try to handle reflection to some extend.
I think it would be a good idea if you can de-embed your trace/connectors s-parameter model and then use with IBIS-AMI model of the redrivers.
Do you have a block diagram that you can share with us? This should show insertion loss at each point.
Regards,,nasser
