Part Number: AM26LS31
My customer is considering about the device behavior when VCC for driver IC, AM26LS31, is turned off and the output pin is pulled up to VCC by pull up resistor on receiver side. Is there any problem in the situation?
Customer worry about that any current flow into the output pin in the situation.
I believe that It's no problem based on internal circuit which is described in the datasheet, if there isn't any additional circuit, ESD circuit or something, in actual device.
Best Regards, Taki
