Part Number: DP83867E
Does DP83867E PHY will support LINK-PP, LPJG16314A4NL RJ-45 ?
Vamsi,
The Link-PP LPJG16314A4NL isn't acceptable for the DP83867 devices. The center taps close to the PHY must not be connected on a single net.
Any magnetics used with the DP83867 should have a schematic similar to the figure 26 in the datasheet. The most critical point is this center tap nets are not joined.
