Part Number: TPS25810
Other Parts Discussed in Thread: HD3SS3220
My customer would like to convert a USB type A to USB type C, with 5V 3A power advertising, USB 2 and USB3/3.1 signal. Do not need DP.
had selected TPS25810 + HD3SS3220.
As TPS25810 does not implement PD, does that means it will not be able to identify e-mark cables? if that is the case, will it violate the USB-C cable assembly requirement? (It says that e-marked cables is required if USB3.1 and 3A is supported).
