Part Number: TPS65988
Hi Team
We want use TPS65988 on Type C dongle with cable. We want support 20V@5A.
PDO will setting 20V@5A , Did we need e-mark chip on system or just setting PDO for 100W ?
Hi Team
Hi Kerr,
You would need an e-marked cable to advertise 20V@5A if your design is using a receptacle. If your design is using a plug, then you would not need the e-marker in the plug since the cable type would be known.
If this answers your question, PLEASE select This resolved my issue
Thank you,
Eric
Hi Eric
Thank you so much. I have setting PDO 20V@5A and Receptacle type is Tethered fully-featured cable with USB-C plug.
But CC log show 20V@3A , Have any other setting?
Hi Kerr,
I just checked on this with the team. It turns out that you would still need to have an e-marker when setting the Receptacle Type to "Tethered fully-featured USB-C plug" as the TPS65988 does not complete the SOP' termination that an e-marker would do.
Thank you,
Eric
