Part Number: TUSB1064RNQEVM
I have connected a tusb1064rnqevm board to my PC (through usb-c cable) and a Monitor through a Display Port (DP) cable, but it doesn't work and it does not detect any external monitor.
Do you have any suggestion about the correct setup?
Is it possible to do that using the default configuration stored in the flash?
What is the correct configuration for all GPIO available on the board?
Speaking about power, does it need the external power supply or it take whatever energy it need from the usb-c?
Is any i2c configuration required to let PD working?
thanks
