Part Number: DP159RGZEVM
Other Parts Discussed in Thread: TUSB1064RNQEVM
I am planning to use DP159RGZ Evaluation Module in order to convert DP signal to HDMI.
When I connect the board to a monitor (HDMI in) and a PC (DP out), it works out of the box.
If I connect the DP159RGZEVM to another board that does the usb-c to DP conversion it does not work.
Do you have any suggestion on how to solve this issue?
Here more details on the configuration:
I am using the following devices
- DP159RGZEMV (DP to HDMI conversion) [default jumper configuration]
- TUSB1064RNQEVM (usb-c to DP and USB3) [default jumper configuration]
Both boards work fine if connected stand alone between PC and monitor.
If I do the following connection:
PC -> usb-c cable -> TUSB1064RNQEVM -> DP cable -> DP159RGZEMV -> HDMI cable -> monitor
It does not work, no display image on the monitor.
Hope you could give me any useful advice.
best regards
Fabrizio
