Part Number: TUSB2046B
Other Parts Discussed in Thread: TUSB2036
I have your TUSB2046B in a new design. When I plug in the upstream port windows responds and it sounds like it might be working but upon checking the device manager in windows it reports
"A request for the USB device descriptor failed" unknown usb device. I have had problems with this for 2 days now. The suspend line goes low momentarily but then goes high again. Does windows need special drivers installed? I am running windows 8. I see other people have had this same problem with no solution! I have gone over all the posts and made sure my device is getting reset properly and all the pins are hi/low properly etc. I have tried 1.5 pull up on both DP0 line and then on the DM0 line. No luck.
I just discovered that when I set DP0 high thru a 1.5k resistor instead of DM0 that windows reports that device is working correctly! But the suspend line toggles low for a few milliseconds and then goes high again when plugging in and unplugging the upstream port and the hub still does not work.
